Results 1 to 7 of 7
Thread: Finally Got my test Kit in the mail
    Sep 2015
    Phoenix, az
    15
    Well I finally got my TF-100 test kit and tested my pool. I am still working on how many gallons my pool holds.
    Below are my results of the test.
    PH = 7.8
    Cl = 2
    BR=4
    FC=2.5
    CC= 0
    CH= 175ppm
    TA= 100
    CYA= 40
    I have also included a pic.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    Re: Finally Got my test Kit in the mail
    Awesome job getting and using a wonderful test kit! GOOD JOB!
    As you can see from this link your numbers look pretty good!
    Your CH is low for a plaster pool.
    Your FC is a tad low as well.
    Here is another link to help you know what to buy to adjust your levels.
    Kim
    Sep 2015
    Phoenix, az
    15
    Thanks Kim,
    I know nothing about pools, but learning a lot more thanks to this
    Also since my other levels are ok,
    How often should I add bleach & run the pump?
    Aug 2014
    Northern IL
    4,615
    You need to get the FC up ASAP. See: Pool School - Chlorine / CYA Chart
    Jul 2012
    Tallahassee, FL
    30,510
    You add bleach/chlorine daily. I add mine in the evening after the sun is off the pool. I do this so the FC is able to do it's work without the sun taking any of it. The pump has to run for at least 30 mins to mix it in good.
    I am going to post a few more links. I hope they help. If you have ANY questions PLEASE feel free to ask them. The links are just to guide you.
    Pool School - Determine Pump Run Time
    Now I am going to post THE main reading you should do to make sure you know the whys and hows things are done/said here on TFP.
    This should keep you busy for a few minutes! LOL
    Kim (I look forward to your next question)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    I would be skeptical of that CH reading in Phoenix unless the pool is filled from a water softener. Did you run the CH test until the sample turned sky blue, or just changed from that reddish color to something more like indigo?
    https://www.youtube.com/user/TF100TestKit/videos
    Sep 2015
    Phoenix, az
    15
    Thanks for the youtube videos.
    I tested it again this morning and my CH = 275 ppm.
    And our house does have a water softener. But I am not sure if it is filled from it?
    Quote Originally Posted by kimkats View Post
    Thanks kim.
    Quote Originally Posted by MarianParoo View Post
    Will do. Thanks
