Thread: Hayward Heater IF (ignition failure) spider webs in gas nozzles
    Oct 2015
    Friendswood/Texas
    2
    I recently had a problem with our Hayward H250IDL2 heater. It showed an "IF" code, which stands for Ignition Failure. I do my own maintenance when I am able to, so I pulled the covers off of the unit and started trouble shooting. I did not manage to resolve the problem, so I called my local pool service company. The tech quickly found the problem: spiders had built their little webs in the small, brass gas nozzles! There are four nozzles, and two of them had webs in them. The tech cleaned these out easily, reinstalled them, and tested the heater. It lit off and ran fine! He told me that, in this part of the country, this is a common problem, and usually occurs as fall approaches and the night time temperatures start to get cooler. Plus, he said the spiders love the smell of natural gas!
    I wanted to pass this along, because I had searched for solutions to the "IF" code problem, and never found this mentioned. So...now you all know. It's a quick and easy DIY fix.
    25,000 gal in-ground gunnite pool, built early '90's; attached spa; Hayward H250IDL2 gas heater; Polaris 250
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Hayward Heater IF (ignition failure) spider webs in gas nozzles
    I've found them in my house furnace also!
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
