Results 1 to 10 of 10
Thread: Debating Upgrading Plaster
    Oct 2015
    humble texas
    132
    I looked at upgrading my plaster (wet edge) from the standard grey to Midnight. The PB wants 3500 which seems way way too much. My pool is 4600 square feet. I guess they have a prism technology plaster that is even more they want 5500.00.
    Is this expensive upgrade worth it, my pool is priced at 78000 without deck?
    Apr 2013
    Sacramento, CA
    2,769
    Re: Debating Upgrading Plaster
    Wow that seems a high price for a color upgrade. Ask the contractor for a change order and bid it out yourself. He may be more reasonable.
    Oct 2015
    humble texas
    132
    He dropped to 3k for pebble is that bad considering the size
    Apr 2013
    Sacramento, CA
    2,769
    Wait is your pool actually 4600 sq ft?
    Oct 2015
    humble texas
    132
    Quote Originally Posted by gwegan View Post
    Yes 4600 but I'm not plastering the hot tub and tanning shelves
    Jan 2015
    Austin, TX
    1,095
    4600 is huge! Are you sure? Mine is ~500. I can't imagine 4600. No wonder the upgrade cost is so high.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    Aug 2014
    Houston tx
    2,525
    Umm, Maybe he means 46,000 gallons, which still a huge pool.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Oct 2015
    humble texas
    132
    46,000 gallons.
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Party at your house! That will be an awesome pool!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Quote Originally Posted by badcrc View Post
    46,000 gallons.
    Check your water meter before and after the fill. You may be surprised.
