- Oct 25, 2015
- 5,200
- Plaster
- CircuPool RJ-60 Plus
Folks,
I just thought I'd pass on some great news. I'm very, very new to this TFP technique. I just took over my pool Oct 31 armed with only my TF-100, basic chemicals, and a thorough reading and re-reading of Pool School I started complete testing every day for about 4 days and then most of the tests for the rest of the week. Then I had to make an adjustment to ph, it worked great but then the big challenge (well for novice me anyway) I had to leave town for 9 days! I was sooooo tempted to call the pool people again but I went ahead and did total immersion in all the threads about how to plan to be away. After looking at my average % FC drop I estimated the amount to add to get to about 24 ppm FC and added acid to get my ph on the low end then headed for the airport... just got here an hour ago and guess what? IT WORKED!! Pool looks great and FC is back down to 3.5 ppm right about where I thought it would be. CYA came up a smidge as I hoped with the trichlor addition and I only need to add some acid, and some more trichlor in the morning to get ph back and slowly build my CYA up to the min recommended level.
So if you're just lurking around on here and wondering if you can do this you're just like me a few weeks ago. I'm living proof you can do this. Just read, and read again pool school. Then take the plunge (no pun intended). Even though I'm barely started on the learning curve, I'm really pumped! My wife is even a believer now too!
Chem Geek, Joyfulnoise, Kimkat, Duraleigh, and all the rest of you too-many-to-list experts here, thanks so much for all you do for us newbies!
Best regards,
Chris
Best regards,
Chris
Date | TA | CYA | FC | CC | CH | PH | Actions |
31-Oct-15 | 130 | <20 | 20 | 0 | 225 | 7.6 | |
1-Nov-15 | 130 | <20 | 18 | 0 | 225 | 7.7 | |
2-Nov-15 | 100 | <20 | 14 | 0 | 225 | 7.7 | |
3-Nov-15 | 90 | <20 | 12 | 0 | 250 | 7.5 | |
4-Nov-15 | 90 | 8 | 0 | 7.5 | |||
5-Nov-15 | 90 | 7 | 0 | 250 | 7.6 | ||
6-Nov-15 | 4 | 7.8 | Addded 16 oz muriatic acid 31.45% | ||||
6-Nov-15 | 80 | <20 | 4 | 0 | 275 | 7.4 | 6 hr after acid addition |
7-Nov-15 | 80 | <20 | 2.5 | 0 | 300 | 7.6 | Added 1 gal 10% Cl |
8-Nov-15 | 14 | Added .75 gal 10% Cl, 10 oz 31.45 Muratic Acid, 6 oz trichlor | |||||
9-Nov-15 | |||||||
10-Nov-15 | |||||||
11-Nov-15 | |||||||
12-Nov-15 | |||||||
13-Nov-15 | |||||||
14-Nov-15 | |||||||
15-Nov-15 | |||||||
16-Nov-15 | |||||||
17-Nov-15 | 90 | 20 | 3.5 | 0 | 300 | 8 |
