Results 1 to 11 of 11
Thread: Intro and new play pool build in Fort Worth, TX
    Nov 2015
    Azle
    4
    Hello everyone. We live on 2 acres in a rural area northwest of Fort Worth, TX and we're so excited to be getting ready to sign the contract on our pool! This will be our first pool build and neither my husband or I grew up with pools, so we would greatly appreciate any input, especially on equipment. Here are the details straight from our contract (sorry for any unnecessary information):
    32.6 x 18ft
    87 ft perimeter
    13,882 gallons
    Depth 3 1/2-5-4 ft
    Tanning ledge..still deciding on size..either 10 or 13 ft and depth either 6 or 8 inches with umbrella anchor
    Pebblesheen Blue Granite
    Oklahoma Flagstone coping
    12 ft weeping wall
    Volleyball anchors
    Equipment:
    Computer sys pda-p4
    Computer extra Jandy Valve Accuator
    Jandy Pump Circulation Plus VSPHP270AUT
    Jandy Filter-Cartridge 460sf
    2 LED Jandy Savi Watercolors Lights
    Low Voltage Device Transformer 300 watt
    Sanitizer Chlorinator Nature II Combo Fusion
    Sanitizer Nature II Express w/cartridge
    Cleaner Polaris 280
    Cleaner pump Polaris
    2 quickskim Venturi Skimmers
    Leafvac Debris Cannister
    Our PB originally had an Ozone sanitizing system included, but after researching those on here, we decided to do take that out.
    Hopefully I can get the pictures attached. The 3D pics do not show the Interfab Adrenaline slide that will be off to the right of the boulders. The small bench that we had in front of the boulders is being moved over near the slide.
    Thanks everyone!!
    Jan 2015
    Austin, TX
    1,095
    Re: Intro and new play pool build in Fort Worth, TX
    I love your pool design. A couple comments:
    1. You have a lot of property so perhaps you might want to make the pool slightly bigger. That is a pretty small pool by Sq. Ft.
    2. You should plan on having as much decking as you can afford. Right now from the pictures it seems like a very small amount of decking. I would also make sure you have some way to get to the pool from the house without walking across grass. It will help keep your pool cleaner.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    Nov 2015
    Azle
    4
    Quote Originally Posted by ummgood View Post
    Thanks for your response! Yes, we were wondering if it was on the small side. We may make it a little wider. So you think 35" wide would be better?
    We are doing a few large boulder stepping stones out to the pool. My husband wants there to be grass left in between the patio and pool.
    Aug 2014
    Houston tx
    2,524
    If you have kids, good luck with them using the stones! They are just gonna run across the grass, IMO.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Welcome!! Very pretty design! I would make the pool and deck as large as I could afford! This will be a fun build to watch! Looking forward to seeing your profession with LOTS of pictures. We LOVE pictures!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    Welcome! Beautiful design but yes make it as big as you can afford! Love the table, we used ours all the time. You will love it!
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    Apr 2015
    Niskayuna, NY
    63
    I have no experience with the Nature II system, but if you intend to use TFP methods to care for your pool, you may want to reconsider that system. Usually when I see Nature II mentioned in the other forums, the advice is to abandon that system and just use liquid chlorine. Another alternative that is encouraged here is a salt water generator.
    18x36, 21,000 gallon, in-ground, vinyl, Pentair SWG, DE filter, Pentair 250K Heater, Taylor K-2006, Dolphin Triton
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Yep, ditch the Nature II. No need to add metals (and the stains that will follow) to your pool. I was thinking about the size when I read your post then saw the other suggestion. Of course there is the budget, but just ask Suz if she would prefer a bigger pool given your lot. 35-38' wouldn't be too big.
    I'd veto the hubby on the grass. Make a 5' wide minimum flared sidewalk from the house to pool. However, what is the distance from the house or existing patio to the pool deck?
    I'd decide on exactly what volleyball system you want so the inserts are correct. Really nice ones have stainless sleeves but they are specific to the application. Spend as much time on the accessories as on the equipment, etc for a fantastic finished product. Guarantee that the things you spend the least time researching will be the items to bite you in the butt in the end. And document ALL model numbers (regardless of how much a PB insists its not necessary).
    Very exciting time! Best of luck. And spend lots of time here and on the net in general researching. But only research here for the really important stuff like pool maintenance and everything else!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    OH GOODIE! Another build to help with!
    Everything that was said above me!!!!!!!!! Live and learn from the people who have been there, done that!
    Kim
    Nov 2015
    Azle
    4
    Quote Originally Posted by bmoreswim View Post
    Great things to think about. I think we're planning on the deck starting 18ft from the patio, but I do like the idea of the walkway you described. Definitely something to consider.
    We're going to meet with another pool builder for a second time in a few days, because I still don't know if I'm sold on the company that did this design. Hopefullly we can make up our minds and get this thing started in the next few weeks.
    Thanks for all your input and I will keep you updated!
    Jul 2012
    Tallahassee, FL
    30,535
    On the ledge-------do you want to put chairs or such on them? If so put one or two somewhere and see what size feels good to move around them.
    Use some rope to play with the size to see what works for what you want the ledge for.
    Ask your husband to think what a pain it is going to be to mow, edge around the stepping stones. The grass will try to grow over all of them. MUCH easier to just a solid but pretty walk way from the house to the pool.
    Kim
