Results 1 to 8 of 8
Thread: What is recommended winter water level for my pool
    Nov 2015
    Oxford CT
    47
    This is my third winter with 20 by 40 rectangular vinyl liner pool in CT. The deepest end is about 9 feet deep, the shallow end is 4 feet.
    The first year was a disaster. I've bought the house close to the winter and before I know the ice was in pipes and a skimmer. Somehow the pool survived with no damage.
    The second year I did some reasearch and drained it below skimmer and inlet and return lines. I dont have drain on a bottom , so it's one inlet port , one skimmer and two return line ports. All the ports are 4 inches below the skimmer . So, I've drained the pool at about 5 inches below inlet and return lines, added chemicals and put safety cover over it.
    Everyrthing was just fine until we got several heavy snowfalls last year. The safety cover was caving really bad. Some anchors got pulled away and some spring clips got destroyed.
    Not sure what to do this year.
    • Should I drain it like last year and reinforce ancors and and springs ?
    • Should I put some kind of inflatable bags to support safety cover?
    • Should I keep the water in pool and just blow the lines and cover them?
    I am lost a this point. Thank you for advice.
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: What is recommended winter water level for my pool
    I'm guessing a above ground pool?
    I lower mine as you, 6 inches below return.
    If you cover it, you will have to remove snow ea time significant snow builds on it. A big PITA for above ground pool but needed to be done.
    As like here,I always removed after any snow fall, as the snow could melt, freeze and then the next snow fall would just sit on the layer of ice causing less room to top edge of pool.
    never had luck with air pillows.
    My pool is above ground so if this is an in ground I cant really comment on what happens other than think it would just ruin a cover as with a above ground it can knock down the whole pool by pulling the walls inward.No trees too close so I don't cover anymore, cleaning a few leaves a couple times before it freezes solid is much easier than back strain and the neighbors wondering why in the world am I out in a blizzard shoveling a pool out
    In your signature add what type of pool and all known equipment for the pool so any further questions can be answered easier.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I would get some ice compensator pillows, fix the anchors and springs. and winterize like you did last year. Do you have water bags to help around perimeter of cover?
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    May 2013
    Long Island NY
    419
    If it's a loop loc cover check there website. They give a distance down from the deck/ concrete surface that the cover is warranted too. I think it's 14" maybe 16".
    I have a loop loc and drain mine below the returns to blow lines, the rain will fill it back up over the returns and then I monitor the water level until freeze up. I keep it about 2" below skimmer mouth.
    When it freezes then it will help support snow load without ripping out my anchors.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Nov 2015
    Oxford CT
    47
    It's an inground pool, I've just added signature. for some reason it does not show.
    Inground vinyl liner 20 by 40 pool in North East
    Hayward 1,5 HP super flow pump
    Sand Filter
    Nov 2015
    Oxford CT
    47
    Quote Originally Posted by banditig View Post
    I would get some ice compensator pillows, ?
    I've checked them on eBay and all of them marked as "aboveground pool air pillows". What is the difference? It is a bag floating on the water. Am I missing something?
    Sand Filter
    Jan 2015
    Maritimes
    56
    The issue you had last winter was the heavy snow before the water froze. The weight of the snow last year overloaded these covers and forced them into the water. The ice adds to help support the cover over winter. I know of several covers that pulled anchors out of concrete and the d rings on the springs were ruined. IMO there is nothing you can do. I knew this was happening and managed to clear mine of first couple of snow falls. That darn snow adds insulation and the water can't freeze solid.
    Nov 2015
    Oxford CT
    47
    It looked really scary, We had record amount of snow, though .The cover was caving in really bad. I'm suprised it was just couple anchors and springs that didn't survive.
    Sand Filter
