Results 1 to 8 of 8
Thread: hypothetically.....
    Oct 2015
    San Diego, Ca.
    646
    hypothetically.....
    My CYA is 60
    What happens if I maintain FC at say 20 instead of 5-7?
    Thanks
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: hypothetically.....
    You waste money.....
    Your pool is safe to swim in with FC up to shock level; but a couple of things can occur that will cost you money-
    As FC loss per day is a %, not a fix amount you will use up more FC than you need to
    The higher FC will be harsh on your swim suits and cause them to fade and degrade
    Support the site
    Aug 2014
    Northern IL
    4,615
    You have a plaster pool... Anyone with a vinyl liner, don't even think about it as it will cause your liner to fade too!
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by MarianParoo View Post
    anything below shock level should be safe for a liner
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    You'll waste a lot of bleach is all.
    Aug 2014
    Northern IL
    4,615
    Quote Originally Posted by tim5055 View Post
    Okay, a bit of clarification on my post.
    If anyone reading this for basic info that has a medium to dark blue liner, please avoid higher FC levels unless your chemistry gets out of whack and you need to SLAM. Many liners with darker blue "dyes" may fade at prolonged high FC to CYA ratios.
    Oct 2015
    San Diego, Ca.
    646
    So the 5-7ppm on the CYA sheet is the minimum amount of chlorine needed?
    Richard320's Avatar
    Jan 2010
    19,004
    Quote Originally Posted by Philo View Post
    Pool School - Chlorine / CYA Chart Miniumum FC for 60 CYA is 5. Target is 7ish. What you want to do is figure out how much you lose each day and add just enough to keep you above 5 until you add again. Most of us allow a little breathing room, so we won't drop below 5.5 or 6. So your target may end up being 7.5 or 8. But for starters, use 7 as your target when you use poolmath to dose. If you come up short when you test it the next day, raise the target. The important thing is to always keep it above 5. If you never get algae, it's really easy to keep it away.
