Results 1 to 11 of 11
Thread: Circuit board repair
    Nov 2015
    The Woodlands Texas
    5
    I have a pool and spa pump control model number PSC2202 which is now obsolete. There is a circuit board in the control with the following numbers on it:
    HPP#1102303201 and 1161-100-SA.
    On the circuit board are two rotary switches that appear to be 4 position single pole. One of the switches is intermittent when I press on it. Does anyone know where I could purchase these switches or where I would find components for this board? A new system to replace my obsolete controller is very expensive.
    Thanks for any help.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Circuit board repair
    Google the HPP# and a couple of pricey boards show up for sale on eBay. I really doubt those switches would have been normally replaceable so I think it's going to take some further sleuthing to get replacements.
    Somewhere on those switches is probably a manufacturer's logo or part number or name. Maybe on the bottom, so they'll have to be unsoldered to see.
    Looking at the pad layouts, I wonder if those are just 4 position switches or if they're 4 bit "digital" switches. Do the switches just stop at 4 positions or do they continuously rotate, possibly for multiple turns? If you post pictures of the switches they may be recognizable as being from a major manufacturer.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Nov 2015
    The Woodlands Texas
    5
    Thank-you very much for the feedback. I Googled the board part numbers and came up empty. There is a number on the switch (50K306ME) and I posted a photo. I could not come up with anything on this switch either. I have quite a lot of experience replacing components on a circuit board so if I could find this switch I could easily replace it. If I knew the details on the switch, I could come up with a different type and slave it into the circuit. I may be at a dead end. I appreciate you replaying back.
    Aug 2014
    Shallotte, NC
    693
    They are most likely "purchased parts" and it looks like the manufacturer's name is on the case. Just guessing, but I suspect that they are 50KΩ pots.
    Try Mouser, DigiKey, or the manufacturer....
    May 2015
    Lake Elsinore ca.
    48
    Are you sure the switch/dial is bad? Looks like a single sided circuit board, can have possible broken solder joints. Also try a few drops of wd40 inside the dial to help clean up carbon build up.
    Nov 2015
    The Woodlands Texas
    5
    Great idea, I have some contact cleaner that I will try. It doesnt look like a sealed switch. I believe the swtich is a wafer switch that connects a 50K resistor to the circuit. I have given up looking for the switch so if the contact cleaner works I will be a happy camper. Thank-you for the idea.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Sure looks like there are raised letter markings on the top surface of the pots. What do those markings say?
    Don't agree it's a wafer switch. The reference designations used for those 2 components are VR1 and VR2, indicating they are Variable Resistors, not switches. Agree with ewkearns that they are likely 50KΩ pots.
    Your board is a completely different version from the 1102303201 boards shown in eBay. As 1herm4 said, yours is a single sided board and the eBay ones are clearly double sided or multilayer.
    The pots on your board have very standard pot lead patterns however the one's on eBay have very oddball patterns. Seems like you could easily get some replacement 50K pots to replace what you got. A simple ohmmeter test likely would verify they were 50K ohm pots.
    Good luck.
    Nov 2015
    The Woodlands Texas
    5
    Thank-you gtemkin. There are three leads through the board and the switch has 4 positions. The OEM appears to be Piher in Spain but I have had no luck through any of their distributors or cross reference. I will be removing the board tomorrow to try contact cleaner and as you say a meter will tell me if it is a variable pot. If it is a potentiometer I will be able to slave a sub in. I am definately not an electronic expert so I appreciate the guidance on the desigantion VR1 VR2, makes sense.
    Nov 2015
    The Woodlands Texas
    5
    Success! Contact cleaner resolved the problem. Thanks to everyone that provided feedback - it was very helpful.
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Awesome! I never cease to be amazed at the wealth of information on here and the generous people who are willing to share it.
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    May 2015
    Lake Elsinore ca.
    48
    Glad it worked!
