Results 1 to 10 of 10
Thread: Has your skimmer equalizer flap ever broken?
    Surf Hawk's Avatar
    Sep 2013
    Santa Barbara, CA
    114
    I've had this float assembly for my Pentair U3 skimmer for less than a year, and the little flap that you move to adjust flow from skimmer or drain already broke.
    I could get a new one for $10, but it might just break in the next year anyway. I thought I'd just design and make a better one myself. Would a 316 stainless steel or aluminum part be a problem with pool chemicals?
    Also, if you have had a broken one, chime in because knowing it is a widespread problem would motivate me to take this on.
    22,000 gallon IG; plaster; 16x32 Rectangular, Depth 3.5-8Ft.
    Hayward Pro-Grid DE Filter - 48sqft w/ cellulose fiber & Hayward Energy Flo RS Pump - .75HP (1.85SF)
    Very old 312sqft solar system, TFT-100 Kit with Speedstir
    Jun 2015
    Wildomar, California
    423
    Re: Has your skimmer equalizer flap ever broken?
    Lots of broken ones. I just replace the flap. I suppose SS would work.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,042
    Yep. Broke. Cut a piece of 1/8" plexiglass and drilled a screw hole.
    Surf Hawk's Avatar
    Sep 2013
    Santa Barbara, CA
    114
    You are a genius. Always over-thinking things, me.
    Richard320's Avatar
    Jan 2010
    19,042
    Quote Originally Posted by Surf Hawk View Post
    You don't even have to radius the corners.
    Surf Hawk's Avatar
    Sep 2013
    Santa Barbara, CA
    114
    This is 6061 Aluminum with a round on one side to get as much flow as possible when open. Perhaps I'd like to notch out a half moon on the other side to improve flow when open. Should last.
    mas985's Avatar
    Pleasanton, CA
    11,741
    I took mine off. I think you would want as much flow as possible through the skimmers.
    Mark
    Surf Hawk's Avatar
    Sep 2013
    Santa Barbara, CA
    114
    I actually leave mine mostly fully closed most of the time. It was probably anecdotal but my pool seemed to recover faster from an algae incident when I left it that way. I have a solar cover most of the time anyway, so skimming action isn't really happening.
    Not one to leave a good thing alone, I'm now making a CNC'ed version, I'll post a pic when it's all done.
    30,426
    When skimmers are hooked in series, that equalizer is used to balance the flow between the skimmers......leaving it wide open (or closed) would effectively negate it's purpose.
    mas985's Avatar
    Pleasanton, CA
    11,741
    In that case I would agree but plumbing skimmers in series is not wise thing to do and hopefully not many PBs would do such a foolish thing.
    Mark
