Results 1 to 8 of 8
Thread: Water - City or Well
    Jul 2015
    Poway, CA
    58
    So my current number on the pool is: FC 18, CC .5, Calcium 1250, TA 90, PH 7.8, CYA 90
    I have two options to fill my pool when it gets low and to replace 74% of the water to get the Calcium and CYA down.
    Well Water: FC & CC 0, Calcium 675, TA 190, PH 7.2, CYA 0
    City Water: FC .5, CC 0, Calcium 500, TA 130, PH 8.2, CYA 0
    Thanks for your help.
    27K Gal, IG Plaster, Hayward EcoStar Variable Pump, Pentair DE FNS Plus Filter 24, Hayward AquaRite with extended life T-CELL-15
    The Pool Cleaner Sweep
    Build in 1969
    Water From City
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Water - City or Well
    City water.
    Although there's a Reverse Osmosis company in Escondido. Depending on water restrictions/fees in Poway, you might find it cheaper, especially if he has off-season rates.
    Aug 2014
    Northern IL
    4,615
    Does your well water have metals? Some pool shops are able to check for them.
    Jul 2015
    Poway, CA
    58
    The well water has no metals.
    Aug 2014
    Northern IL
    4,615
    Sweet! Get your calculator out and compare prices on all three! The CH is an issue to keep in mind.
    Jul 2015
    Poway, CA
    58
    City water.
    Richard,
    Which company are you referring to in Escondido?
    T
    hank you for your help!
    Build in 1969
    Water From City
    TF-100 Test Kit
    30,415
    Mine tested for no metals as well for years. Recently, we had to do an AA treatment to remove the iron deposits from the liner.
    I have come to believe that well water (that's all I have access to) is a big problem and I would avoid it.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,771
    +1
    Use the city water even if your well tests no metals...even trace amounts over time (as they accumulate due to evaporation) cause problems, tests are not uber reliable, and wells also typically have maganese, which few test for.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
