Results 1 to 13 of 13
Thread: Gap between coping and tile
    Sep 2015
    PANAMA CITY BEACH, FL.
    6
    I have a small gap between the coping and the tile. The problem being if we have a heavy rain and I don't catch it water goes into that gap under the deck. Over time it can erode under the deck causing it to collapse. My question is can I seal that gap or is it there for a reason
    15k inground oval with spa,plaster, Purex Triton sand filter, Pentair IntelliFlo pump, AquaRite sws, Jandy LRZ heater (used mainly for the spa),Dolphin Nautilus Plus cleaner
    Oct 2015
    Burleson, Texas
    178
    Re: Gap between coping and tile
    I also have what looks like a foam piece that sticks up between the coping and the deck.
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    It can also erode behind the wall of the pool itself. Never overfill or allow the pool to be flooded above the waterline tile, it can cause serious structural problems.
    chiefwej
    30,419
    How big is "small"?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    A picture may be helpful so we can see what you are looking at. You can use photo bucket to add pics.
    Kim
    Oct 2015
    Burleson, Texas
    178
    My neighbor said they are supposed to grout between the coping and tile.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    You could try and match the color with caulk that expands better than grout. Like they said don't let your pool over fill.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Sep 2015
    6
    About 1/8 of an inch
    30,419
    While that is not a very large gap, I would seal it with polyurethane caulk.....readily available at the big box stores.
    You could also likely ignore it as I don't think that's big enough to cause any issues.
    Sep 2015
    6
    I think I will try a clear silicone sealer and see how that does. Thanks
    30,419
    Over time, polyurethane in that exterior situation, will outperform silicone by a pretty good margin. Your call.
    Sep 2015
    6
    Convinced me will try the polyurethane, Thank you for your help
    30,419
    I forgot this caveat, poly is NOT water soluble so will be harder to work with but it also doesn't have that plastic "gloss" that silicone has.
    Additionally, you can often find poly in a "sanded" version which makes it look pretty close to grout.
