spriteman said:dave, all your info has been helpful -- as I am seriously considering doing a set-up similar to yours. I'm a little confused as to what settings you now have in the pool pilot service menus regarding pump configuration.
prior to your integration of the peristaltic pump into your pool pilot setup, I assume you had the following settings (since you are using an external timer to control the pool pump):
PP service menu:
4.0 Installer Menu --> 4.6 Set Pump Config --> "External Timer"
What Pool Pilot service menu settings did you change after integrating the peristaltic pump into the system? I thought you couldn't set a "Pump Program" unless the "Pump Config" was something other than "External Timer" (e.g. One-Speed Pump, Two-Speed Pump, etc.).
I initially had my pump config set as external timer like you mention. I then changed it to two-speed pump. This allows you to setup two different pump programs and the external timer still turns it on like before, but you can now program the acid pump. The AutoPilot thinks you are setting up the high-speed runtime for a two speed pump, as the wording in the pump program says.
You cannot set it up as one-speed pump, because the AutoPilot will not generate chlorine if the pump is turned off.
dave
