Results 1 to 9 of 9
Thread: Beach Entry Code?
    Beach Entry Code?
    We built our pool a year ago and I've never been happy with the beach entry. It seems much too steep at the flagstone portion. Another pool builder tells me there is a code regulating the entry and that it could be an inspection issue upon resale. Does anyone know how I would check on the code issue? This is in Texas. Thanks!
    16 x 36 25,000 gal IG vintage Alladin plaster pool with solar blanket
    DE filter
    Mar 2009
    Glendora, California
    169
    Re: Beach Entry Code?
    I don't live in Texas, but when I do have a question about codes in regards to anything, not just my pool, I call my City Hall. Tell whoever answers you have a question about code requirements for your pool and they should route you to the proper department.
    I would tell them I am looking into building a pool with a beach entry, just incase yours does happen to be out of code.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Block your number from caller i.d. and give them a fake address if they ask for one. That way you avoid a surprise inspection.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Is it possible its the same as a wheel chair ramp. 16" of rise for every 1' of run ?
    The builder should have known the code !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    IIRC, the APSP/ANSI builder's manual states that beach entries should have a max slope of 1' drop in 7' of run.
    Waterworks
    Thanks for that code - that's what I was lookiing for. Here's the catch, I think. There is probably less than 1' drop over 7', but the first foot in (where the flagstone is) is very steep (too steep). After that initial piece it is fine. So it probably meets the "code", but just isn't necessarily safe or appealing.
    DE filter
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Any chance of posting a picture for the experts to look at and maybe determine what happened or is happening to it ?
    Les
    Helpful Links:
    Mar 2009
    169
    Was the pool ever inspected during construction?
    Solaxx Ph-Tek
    I wouldn't say the code applies to exactly a 1' drop over 7'... my interpretation would be any slope that was 1:7 using any type of unit; meaning if that first part is much steeper, it's probably not allowed.
