Thread: Normal for this much DE in bottom of filter?
    Jan 2014
    The Woodlands, TX
    67
    Took mine apart to clean today. Drain plug is very hard to reach, so shop-vacced out the standing water in filter housing.
    Is it normal to have about 10-12" of sludge in the bottom? Seemed like it was mostly DE.....pretty thick after sucking out the water.
    Just wondering if it had been over DE'd last time.
    Brad
    15,000 gallon IG plaster with attached spa. Full Pentair EasyTouch system. IC40 SWG. TFT-100
    38,251
    Re: Normal for this much DE in bottom of filter?
    Not uncommon. Which is why a full tear down is recommended yearly. Backwashing just does not work very well.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Each time you turn off the pump, much of the DE drops off of the grates in the filter to the bottom, when the pump comes back on it swirls around and is redeposited on the grates. Naturally when you tear down the filter you find a lot of DE in the bottom.
    chiefwej
