Results 1 to 12 of 12
Thread: New pump reccomendations
    Hey there everybody, well the motor on my existing pump has died and I having a tough time choosing a replacement. Been thinking either a two speed or VS.
    I'll list my current setup and if someone could recommend me a pump it would be greatly appreciated.
    inground plaster pool, volume: 30k
    to be honest i'm not too sure about the volume. I got that value from a water statement when the pool was replastered and refilled.
    plumbing diameter: 1.5" all around, suction and returns
    previous motor specs: hp: 1
    sf: 1.65
    voltage:220
    current electrical costs: 15 cents per KwH
    usage : ~220 KwH per month, without any pump usage, has not ran for quite a while now
    thanks for the help guys!!
    more images
    http://postimg.org/image/728nmw3ep/a9a66380/
    http://postimg.org/image/swttzc5fv/355a944e/
    http://postimg.org/image/aq7aul9v7/84223084/
    30K inground plaster pool, Pentair FNS plus 48 DE filter, pentair superflo 1.5 HP 2 speed.
    Re: New pump reccomendations
    Nice antique.
    Personally, I think you're better off with a 1 hp 2 speed pump.
    30,431
    What size (in gpm) is your filter?
    The grid filtration area is 48 square feet
    And rated at 96 GPM
    Edit: according to the owners manual, the flow rate for the pentair fns plus 48, with 48" sqft of filtration, is 120 gpm, based on 2.5 GPM per sqft. Poolcenter.com has it listed at 2.0 GPM per sqft , or 96 GPM.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Nice pool in last pic. Either 2 speed or VS would be better than what you have
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    30,431
    With a filter that size, I would suggest a pump capable of delivering just a bit less gpm than your filter is capable of.......that'll work out to about a 1 hp or perhaps 1.5 hp pump.
    The folks that pay the extra bucks for a VS pump really seem to like them but I think a 1.5 hp 2-speed would be an ideal choice.
    Any pumps in particular that you would recommend for my application?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I would get the 1.5 HP for a pool as large as yours.
    30,431
    I have no opinion between brands and the variations within pool pumps are small enough that I am not capable of ascertaining each one. In the 9 years of the forum, no one brand stands out.
    mas985's Avatar
    Pleasanton, CA
    11,741
    The 1.5 HP SuperFlo only produces 4 GPM more than the 1 HP SuperFlo but uses 350 watts to get you that. Hardly worth it.
    Also, the WhisperFlo WFDS-3 (3/4 HP) has about the same flow rate as a SuperFlo 1.5 HP but the Whisperflo uses about 150 watts less power on high speed. I see no reason to go with a SuperFlo 1.5 HP. The 1 HP SuperFlo is more than sufficient.
    Mark
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Disregard my post. I can't delete it. Mark is correct I learn new stuff here all the time. I just preference for a lot of circulation while I'm swimming.
