Thread: Buying a new liner......LIL help here?
    I'm getting ready to order a new liner for my 24' ag pool ,it has 52" walls and the center has been dug about 10" deeper.Do I need an expandble liner? When the installers were excavating for it I asked if I could have it a little deeper in the center.No problem he said "the liner will fit better that way".I assumed at the time it was a standard liner but I don't want to order the wrong size.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Buying a new liner......LIL help here?
    If you could provide more information about the pool, that would be helpful, brand, age etc....Doughboy makes an expandable liner....
    Actually here is a thread that might have some helpful advice...
    http://www.troublefreepool.com/advic...0vinyl%20liner
    and another:
    http://www.troublefreepool.com/18-ag...0vinyl%20liner
    mpatrick14's Avatar
    Jun 2007
    Las Vegas, NV
    42
    If you don't get an expandable overlap or true-expandable variable depth liner, you do run the risk of tearing at the seams, or having to place the liner so the seams are not in the right locations. My experience in this space has been if you use a non-expandable liner (any regular overlap or beaded) and then it tears due to the deeper middle, it will not be covered under warranty.
    I have a deep end of 72 inches, and I am going with the Lomart true-expandable liner because I had issues with a cheaper overlap expandable liner that lasted me only 1 season (partially quality, partially issues with the contractors mistakes in prepping the ground) After the disaster using a lower end liner, I am going to pay more for the Lomart. Lomart is the sister company of doughboy, meaning you can order online, unlike doughboy. I found that poolstore.com/pool-store.com had the best rates
    poolproducts.com has a 10% off coupon if you dign up for their newsletter, but you have to pay tax if they are in your state, which impacts me. Also, it is a custom order there, so it takes longer...
    Hope this helps!
    Mighty Sun/Asahi Midland Bracelss Oval 21 ' x 41' ft with a 6.5 ft deep end! 30,000 gallons of FUN
    Hayward Xstream Cartridge Filter with 150 1.5HP pump
    Pentair Aqualuminator
    Pentair Great White Cleaner/Pool Rover
