Thread: Circulation for overflow pool
    Nov 2015
    UAE
    1
    Hi Everyone,
    I recently moved into a new house that has a perimeter overflow pool that is being maintained by a pool company. We have been having constant problems with water clarity and algae and the maintenance guy has told me it is because the pumps are only drawing water from the surge tank and that is causing problems with the water circulation so he has opened the valve from the main drain 50% and the valve from the surge tank 50% and said this will resolve the issue. The only problem is by doing this it greatly reduces the amount of water passing over the edge. I have spoken to a few people that have said that the main drain on an overflow pool is only used for emptying the pool and the valve should stay closed when under normal operation. Any advise would be greatly appreciated.
    30,408
    Re: Circulation for overflow pool
    Welcome to the forum.
    Algae only grows in a pool where the chlorine is inadequate. At some point, your folks must address the chemistry issues and then work on the mechanical issues.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,431
    Where is UAE?
    I bet you could do a much better job of taking care of your pool than the pool company has. YOU have TFP to help you!
    Share a picture of your pool and equipment and we might be able to help with the circulation.
    BUT like Dave said---------the chemistry HAS to be taken care of first!
    Kim
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,802
    United Arab Emirates?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
