Thread: Do I need to lower my PH to close my pool?
    Feb 2011
    Northeast OK
    26
    FC-8
    TC-0
    TC-8
    PH-7.8
    TA-100
    CH-160
    CYA-55
    Do I need to lower my PH a bit before closing the pool?
    AGP 25,000 gallons
    sand filter
    NE OK
    25,000 gallon
    above ground pool
    sand filter
    May 2015
    Quebec, QC
    37
    Re: Do I need to lower my PH to close my pool?
    Your pool chemistry looks great to me. If you have an ice cover, any under-ice respiration will increase dissolved CO2 and may reduce your pH slightly, although your Alkalinity should buffer this. I would close as is.
    14 x 28 Jacuzzi vinyl inground pool, Jacuzzi Laser 250 sand filter, Hayward 1 HP pump.
    30,421
    Not sure about the pH but i would lower it. The reports of pH going down in a pool are few and far between.
    Perhaps even more important is to bring your FC to SLAM value.
    May 2015
    Quebec, QC
    37
    It depends on organics and length of time of a permanent ice cover. If under-ice microbial degradation occurs, over a period of 2 to 3 months, dissolved CO2 cannot out gas to the atmosphere, so the waters will tend to acidify. In addition, the snowpack is acidic, so depending on the amount of snow precipitation, this can be a second source of acidity.
