Results 1 to 7 of 7
Thread: Where to place my pump and filter
    Aug 2015
    Bethlehem, PA
    3
    Hi all! I'm new to the forum and have been searching for answers to the questions I have but can't seem to find what I need. I'm in the permitting phase of installing a 40x16 foot inground fiberglass pool and where to place the pump and filter seem to be the biggest discussion/argument.. between the husband and myself.
    The pool company highly recommends putting the pump and filter within 20-25 feet away from the deep end. My husband is adamant that he wants it in a shed behind our garage which is approximately 75' away from the deep end of the pool. Since I'm paying a large amount of money to get this pool installed, I want the best possible outcome to keeping my pool clean. The pool company is using 2 inch pipes for the skimmer and drain but 1.5 for the returns. Also providing us with a 2HP Hayward super pump.
    Some other questions I have are below and what else am I missing?
    1. Is it better to have the pump and filter in a ventilated area or is inside a shed OK? I'm in Bethlehem, PA and the temps in the summer get very high with high humidity.
    2. If the pump and filter are further away from the pool is it inconvenient to do the daily/weekly/monthly maintenance I need to do? Remember, it will most likely all be on me to keep up with the pool.
    3. Is it more difficult to winterize or open the pool if the pump is so far away from the pool?
    4. Will the pressure be sufficient to keep the pool clean like it should be if the pump is so far from the pool?
    Tanya
    Pending Pool Install, pending water test kit
    24K gal, IG Fiberglass, 1 or 2(pending) HP Hayward super pump, sand filter, Dolphin- Active 10
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: Where to place my pump and filter
    20-25' from the deep end seems a little excessive, there is not may pools that would meet this 'recommendation'.
    75' is not excessive, with the pipe diameters you are installing.
    Elevation (head) is another consideration. If the pump has to overcome an elevated pool relative to its own location that reduces the output of the pump at the delivery point.
    1. Pump equipment can be placed outside in the rain so humidity is not an issue. Any pump house should have some ventilation to prevent it becoming a moldy cave. During winter I expect you would winterize your equipment to not freezing concerns. If it were a DE or cartridge filter you would want a way of draining the filter and room to disassemble it.
    2. Your maintenance involving the pool equipment is minimal; checking filter pressure once a week. Occasional pump basket cleaning and filter backwashing. The daily activity does not require you going to the pump house.
    3. No difference, you still drain the lines in the same manner, just a little more water.
    4. If you are using a cleaning robot (Dolphin?) water pressure is not relevant, If you are using a pressure side cleaner then what type makes a big difference on requirements.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Apr 2015
    Mount Pleasant/Wi
    53
    I live in Wisconsin, gets pretty hot and humid here (between Milwaukee and Chicago) and gets plenty cold in the winter!
    My filter and pump are both located inside our attached garage with similar plumbing as you mentioned in your post. Probably a good 65' away from the deep end all buried underground with the valves placed just outside the back where the plumbing enters our garage.
    We do use a dolphin cleaning robot so never an issue with water pressure, but I can assure you the return jets are pushing plenty of water
    No troubles that I can tell so far, we've only owned the home / pool for one season so far but it is the same setup since the previous owners built the pool 15+ years ago.
    Steve
    22,041 IG Vinyl Fiberglass Steps (Built 1990-ish), Dura-Glas Pump, Baker II Series Sand Filter HR-24, TF100 Test Kit w/speedstir
    475 Gallon Caldera Utopia Series Geneva 6 person spa
    Mount Pleasant Wi.
    Aug 2015
    Bethlehem, PA
    3
    Quote Originally Posted by ozdiver View Post
    Thank you for your response ozdiver! This alleviates some of my concerns except for this statement, "Elevation (head) is another consideration. If the pump has to overcome an elevated pool relative to its own location that reduces the output of the pump at the delivery point."
    The pump would be downhill from the pool. Not really sure what the slope is but it's definitely there.
    Tanya
    30,432
    That's not a big deal but if the pump is below the level of the pool water level, you will have to make some plumbing considerations.
    Probably a foot above the pool water level is ideal.
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    124
    Our equipment pad is downhill from our pool so the water is approx. 2' deep in our filter when we open it to clean it and our plumbing from the skimmer to the pump is at least 60 feet. We have a single speed 2HP pentair pump and have not had any problems with the pump priming or the output. It is actually much stronger than I thought it would be. The only issue we currently have is we don't have a valve to shut off water flow so when we open pump basket to clean we are flooded with water which makes it difficult and we have to work quickly. We are installing a valve before we open next year to fix this problem...
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
    Aug 2015
    Bethlehem, PA
    3
    Hi sgarofalo - sorry if I missed on your signature but what HP pump is that Dura-Glas?
    Tanya
