Thread: What are spa fine fountain jets?
    Nov 2015
    Sherman CT
    2
    Fountain Jets
    I have small leaks in 2 jets. The leaks are on the underside of the tub. It would be difficult to get to them since the tub is in an enclosure where I could not work on them.
    I purchased SEA KLEAR SPA "LEAK SEALER". The instructions say DO NOT USE if you have FINE FOUNTAIN jets since they may block when using this product.
    I can't seem to get a definition of FINE FOUNTAIN jets. What are they? What do they look like?
    Nov 2015
    Mount Juliet, TN (just outside Nashville)
    7
    Re: What are spa fine fountain jets?
    I would assume they mean jets with very small openings where the water comes out. Since the leak sealer will plug a leak, it would also have the same effect on a jet with a small hole. The leak sealer can't tell the difference between a pinhole in a line somewhere and a jet with a very small opening.
    14,000 Gallon IG vinyl pool with SWG, Island Spa 450 Gallons chlorine
