Thread: chemical relationships and side-effects
    Houston, TX
    1,099
    Hello to all,
    Is there a chart or place that provides the relationships btw any one of the main 5 test readings [FC, TA, CYA, TC, pH, etc] that if they are off, what it does to the pool and/or what imbalances it causes and what are the fixes?
    Thank you very much,
    tstex
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: chemical relationships and side-effects
    Yes, read this - Pool School - ABCs of Pool Water Chemistry
    That pared with Pool Math (link at the top of every page) will help you calculate any changes you need to make. Look at the bottom of Pool,Math as there is a section on the effects of adding chemicals.
    Support the site
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    The closest I can think of is good, ole Pool Math
    http://www.troublefreepool.com/calc.html
    Look at PH. Notice that it talks about TA and borates.
    The other link I can think of is this one:
    It tells you what to add or do if XX or YY is happening with your levels.
    Is there any one thing you are thinking of or having problems with?
    Kim
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    If it was only that simple!
    ABC's of Pool Water Chemistry is about as close to a single source.
    It's not that complicated, but there are many subtle connections between one parameter and the others.
    Houston, TX
    1,099
    Thank you folks. I know as time progresses and I do more testing read up real time on results, it's that type of experience and interaction that one learns...just wanted to jump start it - thanks again
