Hello to all,
We've been getting some kind of particles in the SPA via the blower. Now have been running in SPA mode for 10 min's 3-4 days per week, w BLOWER too for 1-2 min's. The SPA spills over into POOL when main VSP is on daily.
The pool guy came [we are now using liquid bleach bc I wanted to get rid of pucks due to their infamous higher CYA levels] and applied some more liq bleach [12.5%] and I think he ran some in the blower to disinfect it. Well, I did the quick FC & pH test and the FC was orange and off the charts The pH was at the top or 7.8-8.2 range. When I test the FC & CC via TF-100, I used 34 drops to clear the water, so that's an of 17.
I did not perform any other tests, but I am filling the pool w about another inch of water to the drain line. It is not sunny now and the CYA was last tested at 55-60 about a week ago. I am wanting to know what I need to do or not do at this point? Also, it is ok to use the SPA tonight or are the FC levels way too high?
Thank you,
tstex
Thank you,
tstex
