Thread: Just received my first estimates.... would love feedback
    Nov 2015
    Lawrence, KS
    69
    I live in Northeast Kansas and we are considering an inground pool. I have talked to a few companies and received my first two estimates today. This is an apples to apples comparison for the most part with the exception of the wall construction. I will explain in more detail below but here are the specifics:
    Size: 18x38 rectangle
    Type: Vinyl Liner
    Depth: 3.5ft gradually moving to 6ft
    Chemicals: Salt water system
    Cover: Automatic cover
    Heater type: Gas
    Decking: 900 sq ft regular concrete
    Lights: 2 LED lights
    Quote 1:
    $67,000 - walls made of Steel and size is 18x36 instead of 18x38
    Quote 2:
    $48,000 - walls made of concrete
    Both of these companies are very reputable and have been in business for 25+ years. I have friends who have used both companies and are very pleased with the service of both. I'm very confused about the $20,000 in price difference, especially since the higher quote is for a smaller pool.
    I would love to hear feedback from the group on these estimates.
    thanks
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Re: Just received my first estimates.... would love feedback
    Yikes, big difference. The latter is not a particularly common method of construction I've seen often here. I would have thought the reverse would be true on pricing due to concrete (and size as you mention). I have no personal experience with concrete walled vinyl pools though.
    Are the LED's color changing - if not, I'd specify that - they are fantastic. Autocovers have several different options and methods on construction for the pits. Are they quoting identical setups on that line item? Is there automation and is it the same?
    I'd also HIGHLY recommend combing this back with your original thread (I thought this was a new member for example). You have followers there and you lose the continuity of thoughts by breaking it out. Mods?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    My inground vinyl has a concrete shell (and not the even more rare originally plaster > converted to vinyl)...it was surprising...didn't know they existed til I first saw my now house.
    I won't have to deal with any rust potential or vermiculite issues i guess.
    Dolphin E10 Cleaning Robot.
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    There was another pool build shown up on Long Island using cement walls and it looked fabulous! I wondered if the cement is preferred in areas with harsher winters?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Most construction methods I'm familiar with for vinyl would use steel or polymer walls. Did the second vendor elaborate on the why-fores of concrete? Even though its cheaper price wise, might be some actual benefits to concrete walls... It might just be that its rare because the forms are an expensive investment for the installer.
    Regarding steel, my understanding is that over time with small leaks etc. they can rust a bit under liner, moreso with swg, which is why some installers prefer the polymer walls...which may also be less expensive. Both are better than former wood construction in terms of longevity. (Mine are steel, 15 yrs old, and when I get around to changing the liner I am expecting a bit of patchwork in a few areas, but we'll see
    Given that the auto over is making up about 11,000ish of each bid, that would make your steel wall install cost about $56k (which is a little closer to numbers I've heard) and the concrete approach $37k.
    Have either given you line items or rough breakdowns of the package price (eg equipment, excavation, surround, electrical, plumbing etc.?) Have either specified the liner thickness, brand, etc.? Or confirmed vermiculite floor vs. gravel dust?
    Did either specify the brand of autocover?
    I'm trying to figure out some basis for comparison for you Best bet is to ask the steel guy if polymer walls are available, if they make any price difference, and tell him you're trying to make sense of a wide differential in estimates....I'm betting he'll tell you exactly why its different. Then ask concrete guy the merits of concrete, why its cheaper than sterl or polymer walls etc.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Nov 2015
    Overland Park, KS
    1
    We just put a somewhat similar pool (liner with concrete - 20 x 40 freeform shape, 4' to 6' depth, saltwater, gas heat, but we have a hot tub and sun shelf also) in this year in eastern Kansas also. We received several levels of quotes when we were shopping around also. The base price for the pool, gas heater, salt system, Easy Touch 8 automation, 4 lights (I didn't include the extras-spa, etc we have) was right about in between your two quotes. Concrete decking was $7/sqft for colored broomed and $11/sqft for colored stamped. We used colored broom around the pool and colored stamped concrete on an upper area where we also put a fireplace in. Other items to consider are a cover for the winter, and automatic pool cleaner (it's great).
