Results 1 to 7 of 7
Thread: How to lower CYA?
    Dec 2014
    Cypress, Texas
    200
    How to lower CYA?
    I've been reading up on pool maintenance on this site in anticipation of building our first pool this winter. I think I kind of understand the relationship between FC/CYA, but was wondering that if over time CYA climbs too high, is there a way to reduce it besides doing a partial drain and refill? Also, at what point would this recourse be a consideration?
    2016 Build: 32x8 Gunite, 6,700 gallon IG pool including 6x8 spa and 6x8 tanning ledge w/ 2 bubblers. 32' raised wall with two sheer descent water features. Travertine Coping w/ split faced Travertine on raised wall face. 2HP VS Jandy pump, 400k heater, Rainbow Chlorinator, 4 Colored LED Lights. 459sqft spray deck plus. IAqualink remote, Polarus 9350 Robot Cleaner.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: How to lower CYA?
    CYA can only be lowered by water replacement or by reverse osmosis treatment of the water. Reverse osmosis treatment is not always available and only a last resort if you are on a very strict water limitation. Water, while a precious resource is almost always cheaper than reverse osmosis. You can see from the Pool School - Chlorine / CYA Chart that depending on your chlorination type (manual or SWG) you should lower CYA when it's above 60 for manual chlorination or above 80 for SWG chlorination.
    Isolated Spa - 345 Gallons
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,213
    Nice to see you doing your homework ahead of time!
    Joel has explained it well, water replacement or RO.
    The key to our whole system of pool care is accurate testing and knowing what you add to the pool will do to the pool BEFORE you add it.
    Support the site
    Dec 2014
    Cypress, Texas
    200
    Quote Originally Posted by tim5055 View Post
    Yea, that's what I thought about water replacement. So that leads me to wonder what other people that don't follow the TFPC Method do. From what I understand, using DiChlor/TriChlor tablets can raise the CYA pretty quickly. So, are those people partially draining and refilling their pools constantly?
    Oct 2015
    San Diego, Ca.
    655
    Quote Originally Posted by Mamiamjo View Post
    Yep
    Every few tears I mean years.....
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Yes that is just what they do......................or they get a HUGE green mess and come here for help after they have spent $XXXX at the pool store and it did NOT help.
    The pool store will tell you that you water is "old" or in "chlorine lock" AKA the CYA is too high!
    Kim
    May 2014
    Franklin, NC
    9,213
    Some do.
    Some are "lucky" to live in areas that require closing and draining a lot of water each winter.
    Others live in areas blessed with lots of rain to dilute the CYA.
    A small minority are just lucky that even with high CYA their pool remains clear.
    Then the other help pay the boat payments of the pool store owner
    Support the site
