Thread: Recommend a cleaner
    Nov 2015
    Los Angeles, CA
    13
    Recommend a cleaner
    I am looking at a robot also vs the manual or creepy crawly vacuum attached to the skimmer. I would like one that plugs in and runs independent of the pool filtration system.
    I have a 19,000 gallon in ground pool with a painted surface.
    Can anyone recommend a reasonably priced good one?
    Apr 2014
    Mobile, Alabama
    75
    Re: Recommend a cleaner
    I'm still happy with my Dolphin Nautilus Plus. I got it for $688 delivered with an extra set of screens. I'll probably pick up the caddy for it once next season begins.
    Kevin T
    16' x 32' Vinyl Liner Grecian Pool. 20,000 Gallons. Sta-Rite SuperMax 1HP Pump (PHK2RA6E-102L). W. Cooper Ranger Series 25" Sand Filter. Dolphin Nautilus Plus.
    Jun 2011
    Long Beach, CA
    2,790
    You will have to stick with a robot if you want to run it without the pool pump on.
    What's is your max amount that you are willing to spend?
    Usually with robots, the more you pay you get more cleaning power, more features, and they have longer warranties.
    The newer robots have top loading cartridges that make it easier to work with.
    Apr 2015
    Mount Pleasant/Wi
    53
    I have the Dolphin as well. Bought it this summer for our first year with the house and pool and i absolutely LOVE IT! Best $500 ish I ever spent!!!
    Steve
    22,041 IG Vinyl Fiberglass Steps (Built 1990-ish), Dura-Glas Pump, Baker II Series Sand Filter HR-24, TF100 Test Kit w/speedstir
    475 Gallon Caldera Utopia Series Geneva 6 person spa
    Mount Pleasant Wi.
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Where did you buy it? I am looking for next season and the best price I can fine is 688 like a previous poster noted.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Nov 2015
    Los Angeles, CA
    13
    I've only seen the Dolphin for $600-$700. Where did you find it for $500ish. I was looking to not spend more than that.
