Thread: intelliph and cold water?
    Jan 2015
    Las Vegas, NV
    23
    The PH is rising and the system is red because water is cold. I can manually inject with override when it asks. Does it automatically continue to add? Cold water is no reason to not add acid. I got this to automate, if I have to monitor this manually all winter, that is no good. I was planning on just throwing in a floater for CL and let the IntelliPH handle the acid.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: intelliph and cold water?
    The intelliph is designed to run normally at temps above 52 degrees. I doubt your water is colder than that in Vegas already. You may have another issue.
    Isolated Spa - 345 Gallons
    Jan 2015
    Las Vegas, NV
    23
    pool is at 49deg I just don't understand why it wouldn't inject just because the IntelliChlor won't work?
    JoyfulNoise's Avatar
    May 2015
    13,191
    The whole system is designed to just move water when the COLD WATER CUTOFF engages. It's a safety feature. Freeze damage is always a possibility so the system is doing what it is supposed to.
    The good news is this - at 49F, nothing is happening to your water that is of any major concern.
    Matt
