Thread: Gunite pool
    Nov 2015
    Berkeley heights, N.J
    1
    Gunite pool
    Hi
    Im looking to purchase a home with gunite pool. The house was built in 1985. The pool was neglected and not covered properly and has not been open at least for 4 years. The water heater has rust on it. There are somecracks outside the pool and The rim around the pool has crumbled a little bit .not everywhere just on some parts of the rim. The bank had try to cover up this pool with some wood, chicken wire ,and cheap plastic. When getting it inspected yesterday inspector took one look at the Pool and said its done; and it's going to cost $80,000 to either remove or fix . The pool is holding water pretty much to the top . And besides a little cracks and some busting around the rim everything else seems to be in good condition . Is it possible just to look at a pool and Assume it's "shot" ?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Gunite pool
    I would think if its full, it should be cheaper to fix than 80k.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    30,408
    Re: Gunite pool
    That 80k is from an uninformed person just trying to be safe. 1/4 that would get that pool in top shape as long as you don't go overboard on finishes.
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Re: Gunite pool
    that price is crazy especially if its holding water. pictures?
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Oct 2015
    San Diego, Ca.
    637
    Re: Gunite pool
    You could build a cool deck over the top and be done with it.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
