Thread: Polaris Blower Motor Unseated
    Aug 2015
    McKinney, TX
    4
    Good afternoon, gang!
    I have a Polaris blower (pictured) in which the blower itself is coming unseated, or popping up out of place as soon as it is turned on. Being a relatively new pool owner, the is the first time I've worked on any of my equipment.
    Is the blower supposed to remain seated merely with pressure, or is there supposed to be some sort of latch that keeps it from popping up? I'm not thinking that it's a clogged PVC pipe creating back pressure that forces it up, as I notice last week when my spa water was just at the level of the jets that it did, in fact work. This is leading me to believe that air is getting through, but that the increased pressure once the water level is raised is causing the unit to unseat itself.
    Thoughts or ideas??
    Thanks!
    Bruce
    Bruce & Sarah
    37.5k pebble sheen pool, CCP420 cartridge filter system, No SWG
    Jun 2015
    Wildomar, California
    423
    Re: Polaris Blower Motor Unseated
    Where's the top?
    Aug 2015
    McKinney, TX
    4
    I had removed it for the pic. Is the top supposed to sit down tight enough to prevent the blower from popping off? Is it SUPPOSED to push up against the top? (I certainly wouldn't think so.) ???
    Bruce & Sarah
    Jun 2015
    423
    Sometimes the blower will come loose because the pipe has slightly melted. Glue is not to be used. The answer is to fix the blower on to the pipe with screws, at least 4. That will keep it from blowing off.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Mine has one screw in the PVC union in which one time the screw got loose and fell out causing the blower to pop off the PVC pipe. Just put the screw back in and tightened.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
