Thread: Concrete in groud pool
    Nov 2015
    Auckland NZ
    1
    I am building a concrete in ground pool here in Auckland NZ. It has a hydrostatic valve in floor, can anyone tell me how they are fitted into concrete,
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Re: Concrete in groud pool
    I've only seen hydrostatic valve plumbed in the main drain. My main drain has two 2" threaded holes, one goes to the pool pump, and the other I blocked off, but if I had a concrete floor (I did vermiculite) I would have used a hydrostatic valve. Maybe on your side of the world they plumb them independent of the main drain and they make a special fixture they would screw into, in the floor.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Apr 2013
    Sacramento, CA
    2,769
    Instructions come with the valve. Generally for a gunite pool you leave a hole next to the main drain or in the deepest location in the pool. The penetration should be lightly larger than the diamater of the valve. When you plaster toe pool you clean out the penetration and plaster the valve in place.
