Thread: Quick chem question
    Jul 2015
    Scotch Plains, NJ
    33
    Quick chem question
    Hi all,
    This is my first year with a pool and going into the winter. I know it's bad to store bleach and muriatic acid together, but is this only if opened? Is it OK to keep two, 1 gallon, un-opened bottles of each of these in a medium-sized outdoor plastic storage bin? I have other chems in there, including 1 large bin of tabs.
    Also, if anyone has a recommendation for a solid but inexpensive sump pump for an inground pool with a mesh safety cover, love to hear!
    Steve
    1964 Sylvan 18' x 46' in-ground - 32,000 Gal - re-plastered June 14, 2015, Diamond Brite quartz plaster - Hayward DE 4820 Filter - 1.0 HP Emerson motor with a Hayward super pump
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,537
    Re: Quick chem question
    Muriatic acid's cap is vented even before it is opened. Yes there is a seal on it but it is not air tight. Most of the time when I go to open a new bottle of MA the inside seal is NOT on all of the way.
    Better safe than sorry----------------keep them apart open or unopened.
    Kim
    Jul 2015
    Scotch Plains, NJ
    33
    Makes sense. Thanks Kim.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    As a FYI Steve,
    should an accident occur and the bleach and MA get combined, its more than just a bit dangerous. It's lethal. That combinatin can cause death with just a couple of whiffs.
    Never attempt to mix the two, or store them in close proximity.
    Divin Dave,
    Aug 2014
    Shallotte, NC
    693
    In addition to all of the above, do not store muriatic acid anywhere near anything metal that you would like to keep in decent shape. Definitely, do not store MA in a garage or near tools, etc. Mine stays in an open shed, where the wind keeps the outgassing of the bottle wafted away.
