Thread: What the heck is this plumbing?
    Nov 2015
    Wilmington NC
    7
    Hello all. I am a neophyte pool owner, and I am trying to figure out where my plumbing is going. I have followed the green to crystal clear thread to reclaim my pool, but I am seeing debris return when I vacuum and I have no idea where it is coming from. Can anyone tell me where these lines may come from? I have two pipes in my single skimmer, as well as a main drain, but I'm not sure what is going on as far as plumbing. Here is a pic of my suction side plumbing.
    Thanks!
    Adam
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: What the heck is this plumbing?
    Welcome!
    Regardless of the plumbing, if the filter pump is also the pump you use when you vacuum, the problem is within the filter. You don't have a multiport valve. There's no way something can bypass the valve. Therefore, debris is bypassing the filter. Odds are something isn't seated properly or you have a torn pleat on the cartridge. Any filter that's working properly will strain out anything big enough to see with the naked eye.
    Time to open it up and have a look.
    30,414
    Welcome to the forum.
    320 makes a universal point that all newbies need to read and remember.
    The pipes in front of your pump allow you to select between skimmer, MD, and perhaps a dedicated suction line. Should be easy to find out which is which as soon as you get a new handle.
    The pipe exiting from the top of your pump obviously goes into the filter and then exits and passes through a chlorinator before returning to the pool.
    320 makes a universal point that all newbies need to read and remember. (said it twice because it's that important.)
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    Mine was broken pleats as mentioned above the only time debris ever returned.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Nov 2015
    Wilmington NC
    7
    Thanks all! I pulled the filter cap and gave the filter a cursory inspection the other day, but I was in a hurry and will give it a thorough inspection this weekend the good news is that the pool is vastly improved already. Of course now it's pouring nonstop... :/
