Thread: First TF-100 Test _ Need Advice Please
    Nov 2015
    Katy, TX
    46
    So having done a lot of reading around the subject I ordered the TF-100 test kit and completed my first tests this morning.
    Results are:
    pH 8.2 (I know this is high - what do I add to lower it?)
    FC 2ppm
    CC 0.5ppm
    TC 2.5ppm
    CH 175ppm
    TA 330ppm
    CYA 30ppm
    It seems that the CYA and FC combination is acceptable from looking at the CYA - FC chart, although I should be targeting slightly higher. I have a Pentair Rainbow 320 chlorinator that was set at 3. Increased that to 4 today to try and up the FC a bit.
    I think CH is OK?
    Main concern is the high TA and high pH - recommendations on what I need to do to rectify that.
    Pool is inground plaster pool and was completed approximately 4 weeks ago. 19000 gallons with raised spa with spill way.
    I had the water tested at SunTex pools two weeks ago. Results from that test were:
    pH >8.6
    FC 0.1ppm
    CC 1.1ppm
    TC 1.2ppm
    CH 129ppm
    TA 204ppm
    CYA 9ppm
    On their recommendation I added 1 gallon acid and 60lbs of Proteam Supreme Plus (in 3 equal doses, each a day apart). They did comment that the FC was low but recommended not shocking a new plaster pool (?)
    Recommendations on what I now need to do would be much appreciated
    Thanks
    Dave
    In Ground Gunite with PebbleTec finish, 16.5ft x 35ft, 18600 gallons
    Elevated Spa with spillway
    Pentair Cartridge Filter, Pentair Pumps and Controller
    TF-100 Test Kit
    Located in Katy, TX
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,467
    Re: First TF-100 Test _ Need Advice Please
    Here is a wonderful tool you will LOVE once you learn to use it. It is not hard but does take some playing around with:
    http://www.troublefreepool.com/calc.html
    Here is a link to the levels for each part:
    What to use to make the water do what you want it to:
    Do what your PB tells you to over what this link says because he holds the warranty card!
    Pool School - Start-up New Plaster
    I hope this helps!
    Kim
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Quote Originally Posted by usdave1t View Post
    CH 175ppm
    TA 330ppm
    Hi Dave
    First of all, welcome to TFP!
    I'm up in The Woodlands and I just filled my pool. PB hasn't even turned on the pumps yet. Tested my fill water and got pH >= 8.2 and TA also 330 (something in the Houston area water?). Oddly enough, my CH was only about 75. Just wanted to let you know you're not alone. Good luck.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    New plaster requires proper startup procedures or the plaster can be permanently damaged. You're at risk for scaling with your numbers. The builder should give detailed instructions. Also, the plaster mix manufacturer should have a detailed startup procedure. Make sure that you register the warranty with them. What plaster mix did you get? What instructions were you given?
    Support the site
    Nov 2015
    Katy, TX
    46
    Quote Originally Posted by JamesW View Post
    Well interestingly I didn't get any instructions from the builder. I have a pebbletec finish and have registered the warranty. TexSun pools are contracted by my builder to do the startup and the 'pool school' - pool school was pretty rudimentary and I pretty much could have figured out everything he told me myself. As far as chemicals go, the guy just told me to take water sample to the store and have it tested and they will tell me what to do - I was not very impressed with the guy in the store when I did this so thought I would go the DIY route.
    Looks like I need to go to my builder and see what he says and possibly check with PebbleTec re startup procedures etc
    Thanks for the help
    Dave
    TF-100 Test Kit
    Located in Katy, TX
