Results 1 to 10 of 10
Thread: cracked union nut on my salt cell connection
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Well, winterization went well, until I decided to clean the circupool si30 cell.
    When I went to reinstall it I cracked the nut on the union to cell connection. Nothing like replumbing
    Trying to find the right union locally is proving to be hard. I can get the new unions through circupool. They are a different breed then standard 2" unions. what I'm trying to figure out, are they a pump or heater type union or are they specific to my cell ?
    I'm also wondering if there is a split nut that would work with my cell connection, that would prove to be water tight ? I'm hoping our vast array of experts can save me from myself
    In the meantime, it's Google search. I have all winter to research this and am trying to find the easiest fix. But easiest my not be as good as the "right way" Oh well, any excuse to be on the internet
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Jun 2014
    Roseville, CA
    343
    Re: cracked union nut on my salt cell connection
    Been there.
    I got a nut from Circupool and I cut through it and forced it over the union stub then put a hose clamp over it. You'll need to file the ends to work on snugness, and you'll need Teflon tape on the cell.
    I get a small leak now and then but I can deal with it.
    I've seen unions, etc. melted off but I'm not that brave!
    lefty51's Avatar
    May 2015
    451
    Thanks for the info. originally the nuts where very snug on the tail pieces when I first installed them. Should have addressed it then by trimming a little off the inside of the nuts. The tail piece has that shoulder that makes the inside diameter larger than a standard nut. If I can find a split nut, I may see if I can make it work. If not I may try your idea. When you cut through the nut, did it remove enough material to make the circumference smaller or did it still fit properly ? I would replace the old unions with standard 2" unions but the O ring size and placement wouldn't work.
    Melting them off does sound like something I could screw up,....but hey, it's only re plumbing the entire setup
    Jun 2014
    Roseville, CA
    343
    The Circuppool unions are very tough plastic. Mine seem to be a tad loose. It was a struggle to force them over the old union.
    I'm not familiar with a "split nut".
    In my case I have zero clearance if I make a mistake and ruin the valve with a heat gun.
    What I have works OK for me. Let me know how you ultimately fix it.
    EDIT: I found split nuts. I looked high and low before with no luck. Thanks for that! How do you get the right thread?
    lefty51's Avatar
    May 2015
    451
    I'm not sure about the threads. Ironically I have a 1 1/2 unions on my aerator setup. one brand I think is Mueller, the other Lasco. The nuts will not interchange with the tail pieces, as they "bind" up about a third of the way on, yet either nut threads on to the salt cell with no problem.
    Maybe one of our plumbing pros can explain the threads, the unions have a "flat thread" while the salt cell and it's broken union nut have a "pitch" to the threads. I know I'm not expressing that right.
    There are two piece split nuts with two screws and the kind with a split on one side. but the ones I've seen so far, don't look they would work.
    I'll keep you informed
    lefty51's Avatar
    May 2015
    451
    I love it when the light goes in my head .
    Chuckie, I just reread my last post and realized that I was comparing the inside diameter of the union nut from my 1 1/2" nut with the 2" nut from the salt cell. Duh, of course they would be different
    The threads on the salt cell are "buttress" threads, I believe. The inner diameter of that nut is approx. 70mm. I need to compare it with a 2" union nut. What I don't know is whether they would come in a "buttress" thread.
    From looking around it seems most are either a "v" thread or an "acme or flat" thread. If nothing else, I'm educating myself on pvc fittings and thread types, so that's a good thing. What I have noticed is the nuts on a 1 1/2 union are the same as the 2" nuts as far as threading on, yet the 2" is smaller in overall size then the 1 1/2". Hmmm
    UPDATE:
    I think what we are looking for is a "UNRN20" split nut or magic plastics #0121109020 . It seems to be the right dimensions and thread
    Jun 2014
    Roseville, CA
    343
    I just remembered... I had to cut the nut vertically because it was too tall. I used a hose clamp as a guide (so the hack wouldn't travel out of plane) and cut off about 1/4" so it would snug up against the couple part enough to compress the O ring.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Aug 2015
    Maine
    45
    Depending on the crack, you could try Bondic. It is a pretty good at fixing the impossible...
    lefty51's Avatar
    May 2015
    451
    Hi chuckie, just a follow up. I ordered two split nuts, (Valterra KO4052) They are pump union nuts. Installed them yesterday and they worked great. I believe they will seal and not leak, but won't know till spring when I hook the system back up next spring. It cost $13.41, they were $2.96 each, the rest was shipping. That's the bad thing about ordering online, often shipping is more than purchase.
    Makes you appreciate Dave and TFTESTKITS more each day.
    Jun 2014
    Roseville, CA
    343
    Thanks for the follow up, I'm going to go your route instead of my Micky mouse hack job! Lol.
