Thread: FC & CYA - I don't understand...
    Nov 2015
    2
    I'm guessing the answer to this question is obvious and I sound like an idiot for asking, but here goes...
    If CYA (aka conditioner) protects chlorine from being evaporated by sunlight, why do target and shock FC levels go up as CYA goes up?
    It seems like the more chlorine protecting CYA there is in the water, the less chlorine should be required - but the chlorine/CYA chart says the opposite.
    What about this am I missing?
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,246
    Re: FC & CYA - I don't understand...
    For starters, there are no dumb questions here on the Forum. Welcome to TFP!
    Below are links on the relationship between CYA and FC:
    Chlorine / Cyanuric Acid (CYA) Relationship - Pool Genius Network
    Chlorine/CYA relationship
    CYA FC relationship question
    If you use the Advanced Search box, you will find a wealth of information on this forum that covers this topic.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Nov 2015
    2
    Of course - five minutes after I posted this question, I made some progress figuring it out. I'll finish the job with your links.
    You've earned a little good karma today.
    Many thanks.
