Thread: Pentair VS pump
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Pentair VS pump
    i currently have a Hayward single speed 2 hp super pump.
    i want to replace it with a Pentair VS pump.
    Pentair 011018 IntelliFlo 3HP Variable Speed Pool Pump Ultra Energy-Efficient, 230V
    Does anyone know if the plumbing will fit up, or will i need to re-plum the 2 pipes.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Pentair VS pump
    It doesn't just line right up. You will need to do just a bit of plumbing. You are going to want to install the coupling connectors anyway, and they require some plumbing. The couplings make the install much easier. They seal to the pump body by an O-ring that seals against the pump body, rather than relying on pipe dope or Teflon tape. $25-35, but money well spent.
    Depending on whether you have room to move the pump around a little, the discharge can obviously be aligned, but the intake will need to be replumbed. It really isn't very hard. The only real issue is that a DIY install won't get you a full warranty. If you know a plumber, electrician, or pool service that owes you a favor, a receipt for the install sent in with the warranty card will qualify you for the full warranty.
    chiefwej
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Pentair VS pump
    Thanks for the info, trying to get my energy usage down, in the summer the single speed pump is using over 30% of my Energy bill.
    What speeds do you run your pump ?
    I also have a in floor system, and a 72 sq. ft. Hayward progrid D.E. filter, oh yea and a Krepe Krawley.
    Are you using a SWG ?
    Sean Hannon
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Pentair VS pump
    My run schedule in the summer uses four different speeds. I have an in floor cleaning system, a solar heating system, and a Salt Water Chlorine Generator.
    Pump Run Schedule
    RPM Wattage Purpose Start/Stop Hrs
    1,000 100 Extra Filtration 4 pm /11 pm..7
    1,400 200 Chlorinate 8 am/4 pm........8
    2,800 1,300 Cleaning 5 am/8 am........3
    External Program
    2,550 950 Solar Controller On Demand 40 gpm
    The pump runs 18 hrs a day but most of it is at a power draw of 100 or 200 watts (vs my old pump's nearly 3,000 watt draw). The SWG requires 1200 rpm, (I use 1400 just to be safe). The in floor needs 2,800 rpm to work effectively, and three hours provides two full cleaning cycles. During the day, the solar system ramps up the pump speed to 2,550 if heat is called for and is available at the collectors. The rest of the time the pump runs at 1,000 rpm, drawing just 100 watts.
    During the off season, I just run the three hour a day cleaning cycle. 3 hrs @ 2,800 rpm. It's enough to clean and chlorinate the pool.
    chiefwej
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Pentair VS pump
    That what i needed to know.. Thanks ..
    Sean Hannon
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Pentair VS pump
    Amazon.com: 2 PACK -CMP Hi-Temp Union 2 Garden
    These are the kind of unions you'll want to go with that pump. Awesome pump...you'll love the flexibility.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
