Thread: Poolvergnugen The Pool Cleaner suction side cleaner
    Sep 2015
    La Porte, Texas
    37
    One of the You Tubers seems to like the Hayward Poolvergnugen The Pool Cleaner.
    it looks to be fairly maintenance free (tires need changing), and it picks up fairly large leaves.
    anybody have experience with these? I will be replacing the tires with Vinyl/Fiberglass tires.
    17' x 35' x 8' in ground Vinyl lined, 24400 gal, age unknown
    Pentair Cartridge Filter
    Hayward Super II Pump
    ( liquid bleach)
    Richard
    Jun 2011
    Long Beach, CA
    2,790
    Re: Poolvergnugen The Pool Cleaner suction side cleaner
    That is a highly rated suction side cleaner from all the reports here at TFP. Mine is 5 years old now and the only part that needed to be replaced are one set of tires so far.
    May 2015
    dunnellon fl
    5
    Mine is year old. It jammed with debris once and was easy to clear. I run my VS pump at half speed and divert half the flow to the spa so the speed of the cleaner is much lower than spec. The cleaner works great.
    Jim
    inground concrete with spa and spillover 14,000 ga
    Pentair Intelliflo main pump 1 hp spa pump and reverse cycle electric heater
    Aqua Rite saltwater chlorine generator
    Intermatic PE153 controller for Aqua Rite and spa pump.
    Sep 2015
    La Porte, Texas
    37
    how critical are the Vinyl / Fiberglass tires for a vinyl lined pool?
    ( liquid bleach)
    Richard
