Thread: Worth an upgrade or not? Aqualink
    Oct 2015
    humble texas
    132
    All-
    We signed up for a pool and have a Aquilink 4. Im using all these but curious my LED lights in pool are both wired to one function. Is upgrading the AquilinK to an 8 zone one worth it. Its cost is 1700. At that point I would put in some bubblers.
    Anyone know why else I should upgrade?
    Apr 2013
    Sacramento, CA
    2,769
    Re: Worth an upgrade or not? Aqualink
    Do you have a spa?
    The cost difference is 1700? That seems steep.
    Without knowing the specifics of your pool plan it's difficult for me to comment. For most pools without a spa four relays are sufficient. But I really need more specifics to respond.
    Oct 2015
    humble texas
    132
    Its infinity edge with a reflection spa or negative edge water over flows its all tile...
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Just my 2 cents but I'd go with the aqualink4 and plow the extra $ that you would spend on the 8 into one or more of the optional accessories.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Oct 2015
    humble texas
    132
    What are examples of the accessories?
