Thread: can I let FC drop?
    Jul 2012
    Whidbey Island, WA
    397
    can I let FC drop?
    good evening
    pool not closed and water is getting coooold
    water looks fine
    CYA is 30-40 and PoolMath FC range is 3-7
    can I now run at the low end of the FC range?
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: can I let FC drop?
    You can always run at the lower end of the range, just make sure it never drops below minimum and keep steady with your testing despite likely lower chlorine demand.
    Isolated Spa - 345 Gallons
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by JVTrain View Post
    thank you, will do
    demand is pretty low
    added gallon 10% on 10/23
    was FC 8 the next morning
    and today (11 days later) FC 4.5
