Results 1 to 8 of 8
Thread: Permit required?
    30,403
    Permit required?
    My friend asked me if he needs a permit to erect an AG pool. I am sure it varies by jurisdiction but I have no clue. Anyone?
    Re: Permit required?
    Usually, yes a permit is required unless it's less than 24" tall and no structural frame such as a small blow up pool. In any case it's best to check with the local authority.
    Procedure for Obtaining Swimming Pool Permits
    Also, if the property is covered by a homeowners association, they might have rules that cover such things.
    Support the site
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    100% Depends on the municipality. Some places would let you build a castle without batting an eye, others want a permit if you are putting a new mailbox in.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    22,542
    We don't require permits for anything where I'm located. You could build a space port and not have to have a permit. However the little town to the south of us requires a permit for almost everything, except an above ground pool.
    So, as pinguy said, it 100% depends on the local AHJ.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    It's easier to ask for forgiveness than permission...
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Not when they tell you to take it down.
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Quote Originally Posted by robdac View Post
    That attitude can be very expensive and will frequently land you in court.
    chiefwej
    wjr75's Avatar
    Jun 2013
    IL
    836
    Permit and final inspection for up where I am. Above ground pools usually more worried that there is a good ground fault for the pump.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
