Thread: cya testing
    Mar 2014
    Angleton, Tx
    91
    cya testing
    I know your suppose to test in full sun with your back to the sun. I usually don't get home until after dark, or say the sun isn't out. What do you do then?
    IG Pebble sheen blue surf approx. 14k gallon, beach entry, 7' spa, 3.5 ton jumping rock/waterfall, Pentair 2hp whisper flo, booster pump, 520 cartridge filter, Stenner Econ T, 400k master temp heater, easy touch controls,TF-100 w/speedstir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: cya testing
    Use the brightest indirect indoor light that you can. Perhaps you can verify on the weekend, or your next day off.
    Essential Links:
    Mar 2014
    Angleton, Tx
    91
    Re: cya testing
    Sounds good, thanks
