Thread: Moving in 2 weeks and liner
    I am moving in 2 weeks. I have drained the pool already. What I need to know is if there is any thing I need to worry about now that the pool is empty. Do I need to do Anything special to care for the liner before we set the pool up again?
    Thanks for any advice ......
    Deb
    Intex AG 2252 / 10421 Gallons / Vinyl liner
    Pool Set up - May 2016
    2650 gal/hr Intex Krystal Clear Pump- Type B Filter
    Intex SWG
    TFTestkit / SpeedStir Magnetic Stirrer!!! / BBB method only
    Jun 2014
    14,959
    Re: Moving in 2 weeks and liner
    Hello Deb. If I understand your question correctly, you will be taking this pool with you to your new location correct? If that's the case, you'll want to be concerned with two things: Clean/dry the liner before you roll/fold it up in the move, and protect the liner from damage (cuts, punctures, etc). These two things should keep your liner from getting moldy and/or damaged in the move. At your new location, open the liner and allow it to "breathe" and air-out any moisture that may have been trapped during the move and perform a visual inspection for damage. If it's warm where you are going, the sun's heat should help make the liner more flexible when you go to re-install it. Those would seem to be a couple good basic things to consider. Perhaps others will have another comment or two. Good luck on your move!
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    After drying the liner sprinkle some talc around the inside to help prevent the liner from sticking to itself.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Thank you everyone for your advice. We are just moving next door. I would love to be able to pick up the pool and not have to take it apart. LOL
    Now if the deck would be that easy to move....
    Now would be a good time to switch to salt. Any good recommendations for salt water pump?
    Intex SWG
