Thread: Dolphin Triton Robotic Pool Cleaner any good?
    Oct 2015
    humble texas
    132
    Thinking about getting this for a pool cleaner is it a bad investment for robots?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Re: Dolphin Triton Robotic Pool Cleaner any good?
    I did a search for this cleaner using the TFP search box (right hand side) and found several threads about this cleaner. This search box is great as it searches TFP.
    I do not have this cleaner. I just wanted to let you know about the TFP search box.
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have the dolphin nautilus. Its the same cleaner as the the Triton, except that the Triton has the float handle on it to assisit in cleaning the tile line, plus it can be upgraded to be remote controlled. The drive system and cleaning apparatus are the same.
    I've had my cleaner for a little over 2 years, and aboslutely no problems whatsoever. It does an excellent job of cleaning.
    Divin Dave,
