Results 1 to 8 of 8
Thread: A few questions
    A few questions
    Edited for clarity by inserting paragraph breaks and breaking up run on sentences by TFP Moderator
    I have a 20x40 oval pool above ground I have posted on here before but its been about a year.
    I have had the pool about 3 years and have always had problems. The first year went well with not to many problems,but the second year I had to change the liner.
    Last year i had a constant fight with keeping the water clear, but Im thinking my filter wasn't working properlly,becuase when you turned it to fiter, back wash ect it didnt seems like it was doing any thing (Ie it was moving to easily). So I purchased another filter and pump (the pump is another question later).
    Ok, so my question for the filter is what sand to put in it? Does it have to be sand from pool store? is playbox sand to course or should it be finer? I think that might have been part of the water problem last year the pool is my sister and she bought play box sand to replace it and replaced it herself without me knowing.
    Now on to the pump. I have replaced twice since we've had the pool. It never quits working but it gets real loud, so heres my therory. At first i was thinking because of the wheather always being outside(but than I remebered as a kid we had inground pool and pump was on deck of pool), so my thinking is it my power source. We've always used extension cords even though was a heavier cord--the half inch cord.
    I have a 21x41 oval with a sand filter,2hp motor ,above ground dough boy
    Feb 2008
    Denton, TX
    5,061
    Re: A few questions
    You need to get pool sand for the filter.
    Pool sand is more dense and is designed for filtration purposes. In addition to this, there are quality control steps that are applied to pool sand that are not applied to play sand. I suppose that you would need to get this from a pool store, but I think that I have seen it at the big box stores too (Home Depot). As long as it is marked as pool sand, you should be good.
    30,133
    Re: A few questions
    I'll answer one of those and ask another.
    The only suitable sand is pool filter sand.
    How long is the extension cord out to your pool? What guage is the wire? Does the cord get a little bit hot when the pump is running? (I think you might be correct about the ext. cord being a good part of your pump problems.)
    Guest
    Re: A few questions
    Quote Originally Posted by tosborn55
    It needs to be pool filter sand. This is sand that has the proper size sand grains for filtering.
    Using playsand is very likely the problem. It's not filter sand. There are many different grades of sand used for different purposes such as filtering, sandblasting, and sandboxes!
    If the pump got noisy I would suspect the bearings and I would suspect it's because you ran it dry and it overheated. AGP pumps are NOT self priming and if you let them run dry they will burn out!
    How long is the extension cord you are using? I would not suspect a problem from a short cord that can carry the rated load but I would suspect problems if you are trying to use an under rated or very long cord.
    Re: A few questions
    Well, it's a heavy gauge cord. I'm not sure about gauge, but its a 50' cord. I usally run my welder off of it. I havent really noticed it getting hot though while the pump is on.
    Guest
    Re: A few questions
    A 50 foot cord is probably too long for an inductive load like a motor. It's probably making the pump overheat and damaging the bearings and/or seals.
    Re: A few questions
    So should I run regular 12-2 wire to the pool?
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: A few questions
    I don't think the extension cord is causing your pump motor to overheat, but it would probably be best to put in a feed for the pool, especially since it needs to be on a GFCI breaker. What's the amp rating of your pump? That plus the footage will determine the size of the breaker needed and the gauge of the wire, IIRC.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
