Thread: Laterals - sand filter
    schrody's Avatar
    Aug 2008
    Fort Worth, TX
    75
    When screwing the laterals back in...does it matter what direction the slots are facing? Or is it more important to screw them in tightly?
    I seem to recall the slots facing down when I disassembled but if I screw them in tightly they point in all kinds of directions.
    PS. I'm not claiming my memory is any good.
    12,000 gallons - IG - Vinyl
    IntelliFlo VF Pump
    Tagelus TA-60 Sand Filter
    30,403
    Re: Laterals - sand filter
    Since they are submersed, the direction would seem to be irrelevant. Tight would seem to be the requirement.
    That said, I'm doing something I shouldn't do.....I'm guessing. Some of the folks who truly know the correct answer will be along soon.
    schrody's Avatar
    Aug 2008
    Fort Worth, TX
    75
    That would be my guess too. Thanks for one vote backing it up!
    Adding to the problem...the plastic holder at the bottom of the filter that the lateral assembly sits on top of has come loose. So to add to the debate: do I center it as best as possible and let the weight of sand hold it in place? Or must I go to the hardware store for some type of adhesive?
    Update: Just went to get an epoxy for the holder. Still curious if anyone else has an opinion on the laterals.
    IntelliFlo VF Pump
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    They should be pointed down. It will backwash more effectively that way.
    schrody's Avatar
    Aug 2008
    Fort Worth, TX
    75
    Thank you, sir! I'm just about to cover them. 8)
    IntelliFlo VF Pump
