Results 1 to 9 of 9
Thread: Water sampling
    Mar 2014
    Angleton, Tx
    91
    Water sampling
    Do yall go back and forth to the pool to get each sample or just fill a larger container with water? I have been going back and forth for each test.
    IG Pebble sheen blue surf approx. 14k gallon, beach entry, 7' spa, 3.5 ton jumping rock/waterfall, Pentair 2hp whisper flo, booster pump, 520 cartridge filter, Stenner Econ T, 400k master temp heater, easy touch controls,TF-100 w/speedstir
    Sep 2013
    Charleston, SC
    540
    Re: Water sampling
    I use the bottle the pool store provides and get my water sample once. This is particularly handy in the colder winter months!
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Water sampling
    I have a 250 mL Nalgene bottle that I fill with a pool water sample, bring it inside and do the testing in there, except for CYA testing which has to be done in full sunlight. I also use a 3/4" ID, 4 foot length of PVC and my thumb to draw sample out of the pool from below the surface. Thumb covering the end, push underwater, remove thumb to allow water in the pipe, thumb back over the pipe, then pull the sample out and empty the pipe into the sample bottle. The 4 foot pipe holds plenty to fill the bottle. Hands and arms stay dry doing it that way, which is especially helpful when the pool is cold in the early spring and fall.
    Isolated Spa - 345 Gallons
    Mar 2014
    Angleton, Tx
    91
    Re: Water sampling
    Quote Originally Posted by JVTrain View Post
    I have a 250 mL Nalgene bottle that I fill with a pool water sample, bring it inside and do the testing in there, except for CYA testing which has to be done in full sunlight. I also use a 3/4" length of PVC and my thumb to draw sample out of the pool from below the surface. Thumb covering the end, push underwater, remove thumb to allow water in the pipe, thumb back over the pipe, then pull the sample out and empty the pipe into the sample bottle. The 4 foot pipe holds plenty to fill the bottle. Hands and arms stay dry doing it that way, which is especially helpful when the pool is cold in the early spring and fall.
    good idea! ill have to get me a piece of pvc.
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    465
    Re: Water sampling
    Red Solo Cup. I fill you up!
    Holds more than enough water to do all the tests at one time at my kitchen table. I don't test once the winter cover goes on and I won't test until at least Late April next year. Winter cover won't come off until around Memorial Day.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 29k gal., 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Water sampling
    I use a condiment squeeze bottle from the dollar store. It holds enough for all the tests, and as a bonus, the tip comes just to the 25 ml line when inverted in the test cylinde. A dollar well spent!
    chiefwej
    Mar 2014
    Angleton, Tx
    91
    Re: Water sampling
    yea i think my days of back and forth to the pool are over lol. Thanks everyone
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: Water sampling
    I use a device like this to get a deep water sample -
    It's 3/4" diameter PVC ~ 4 ft long with a ball valve and barbed hose adapter (there's a cap on the end but that's just for storage). You insert the open end of tube into the pool with the ball valve closed, open the ball valve until water flows out the top of the barbed fitting, close the ball valve, lift and rotate the open end up out of the water and then open the ball valve over a container to drain the water out of the PVC tube. The amount of water in the tube EXACTLY fills a Leslie's water sample bottle.
    This design ensures that I get a water sample from approximately the mid point of my deep end.
    Matt
    Mar 2015
    South Texas
    411
    Re: Water sampling
    This is the best idea I've read about in a long time! Thanks for sharing! And JoyfulNoise even improved upon the idea. Thanks you two!
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
