Thread: I am going to repair this but it's not in use, so input
    beachinmoney's Avatar
    Jun 2013
    Buckeye, AZ
    159
    Hi, I need to fix a leak in this pipe where the arrow is but it doesn't connect to the SWG that used to be there. Any way to just get rid of it instead of having to cut it out and repair it?
    Beachinmoney, live in AZ, Pool is inground approx. 14,500 gallons of water. I have a Pentair Intelliflo 2 VST pump. The pool was built in 2006 and Pentair Clean and Clear Plus Filter System. A&A in-ground cleaning system
    Re: I am going to repair this but it's not in use, so input
    Cut it out and be done with it. Simple
    Jun 2013
    Buckeye, AZ
    159
    How do I cut it out is the question?
    I would need a closer picture, but I think you're looking at using a pipe extender for a fitting extender.
    It's a union. Probably just needs a new o ring.
    Built Aug 2015- 20x40 26000 Gallon free form gunite, White plaster w/ 50% blue quartz, 2hp Jandy Stealth, Polaris 280, 2 skimmers,2 floor drains, 5 returns, bubbler, Grotto waterfall. 2 24" sheer decents, Jandy 48 DE filter, Jandy Aquapure PLC1400 SWG, 2 Color changing led
