Thread: Getting ready for winter
    May 2015
    Knoxville TN
    26
    After many years of using clorox, I installed a swcg in the middle of the season this year, WOW. Wish I had done it years ago. But now I'm in uncharted territory. The pump runs and the pool remains open throughout the winter. Do I shut the swcg off or continue to monitor and keep the salt level around 3400? And what else do I need to be aware of as winter approaches?
    Thanks in advance
    35,000 gallon gunite pool. 1 hp hayward pump. Sand filter. Waterfall. 1 main drain. 2 skimmers. 4 returns. 1 1/2" PVC tubing. Maytronics robot.
    Jun 2011
    Long Beach, CA
    2,780
    Re: Getting ready for winter
    It depends on how cold the pool water drops to. As the water gets colder the pool will use less and less chlorine and the SWG output will need to be adjusted accordingly. All SWG's shut off when the water is too cold, usually around 50 degrees or so. At that point it is best to add bleach when needed.
    Jul 2013
    Waxahachie, Tx.
    442
    I shut mine off when the water temp prevents it from generating and the supplement with until spring. Monitoring the other readings of course
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Jul 2013
    Waxahachie, Tx.
    442
    Thats supplement w bleach
