Thread: It's been a while - Revisiting topic of Heat Pumps
    Jun 2015
    Brighton East
    11
    Hi All,
    Another newbie here from Melbourne, Aus.
    My pool has just been finished, although my PB isn't too rushed to finish few issues that have cropped up since.
    I am currently considering my long-term pool heating options. Currently I have Zodiac LZR gas heater. Obviously gas heating is bit on expensive side, so I am currently reviewing Heat Pump options.
    Based on my preliminary research, the heat pumps are the way to go for almost all-year-around heating.
    I have an concrete, in-ground, tiled 60,000L pool.
    So my question is: Can anyone recommend a particular brand/model Heat Pump that would do the job (I understand that I need to get a model suited to my pool size).
    Any brand that I should stay away from?
    I noticed that most major pool equipment manufacturers are now in the business of selling heat pumps.
    Any recommendations would be greatly appreciated.
    Regards
    Vlad
    Sep 2012
    Pittsburgh
    35
    Re: It's been a while - Revisiting topic of Heat Pumps
    i live in pittsburgh pa and have had a heat pump for 4 years. I am going to switch to a gas heater. heat pumps take a very long time to warm up the water and usually do not work well at all when the air temp is 65 or below. hope this helps
    I have been looking at them too. I know there are some issues with some of the manufacturers and warranty if you are not local to them. They dont have a service network.
    Built Aug 2015- 20x40 26000 Gallon free form gunite, White plaster w/ 50% blue quartz, 2hp Jandy Stealth, Polaris 280, 2 skimmers,2 floor drains, 5 returns, bubbler, Grotto waterfall. 2 24" sheer decents, Jandy 48 DE filter, Jandy Aquapure PLC1400 SWG, 2 Color changing led
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    What Awilli8203 said is accurate. Once you get below 65, heat pumps are very inefficient. You have to run them almost constantly during the cooler months in order for them to keep the pool warm. Where as gas you can heat when you want but I guess gas is expensive in your area. Where are you located?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
