Thread: Building our own pool!
    Nov 2015
    qld
    2
    Hi there, we live on The Sunshine Coast in Australia and after receiving a few quotes way past our budget we have decided to build our own. I'm at the stage of slight panic after hearing many negative reactions from (professional pool builders) but have faith in my husband that he can do this.
    It's going to be a 10 meter x 3,5 meter pool. 6 meters will be 2 meters deep the other 4 meters will be 1.20 m deep and seating. We are going to build this pool with besser blocks, then waterproof it, then finish it off with smooth pebble crete.
    We have had the pool engineered and the building certifier is organised, so this weekend hired an excavator to dig the hole. As we are on a very steep slope going down hill and sideways we found that we had to dig 3 meters deep so the far end wall wouldn't come two meters out of the ground.
    I'm now waiting on my husbands calculations for steel and besser blocks so I can get them ordered and delivered. Will keep posting as we make progress. We welcome advise! We also welcome positive and uplifting ideas and help.
    Thanks, Betty
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Re: Building our own pool!
    Hi Betty,
    welcome to TFP!
    We look forward to seeing your project come along!
    Divin Dave,
    Nov 2015
    qld
    2
    Whoops, picture upside down?
    Building our own besser block concrete pool!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    HI! Yeah your pic is upside down since you are on the other side of the world! LOL Not really but...........this happens sometimes. Sideways, up side down, too small, too big....It might take some playing around for you to find the set up that works. Until then we will just stand on our heads to look at your pics!
    To share more pics you can use photobucket.
    Kim
    yellow12's Avatar
    Oct 2015
    Vail, AZ
    81
    Ah ha, upside down from Australia. That was funny Kim. Congrats for having the guts to do it yourself! Me, I am yellow belly Look forward to seeing your project proceed. Wendy
    22x38 with 3 sheer descents, 18" back wall, 4 deck jets, 3 bubblers in lagoon
    25,000 gallons, Standard White Plaster, Pentair Clean and Clear 420 Cartridge Filter Pentair Intelliflo Variable Speed Pump, Pentair Intellibrite LED light
    Circupool Salt System, Polaris-Caretaker 8-port Ultra Flex In-floor Cleaning System
    (Tucson AZ area:Vail)
