Thread: Pool closed for winter. Forgot to remove solar cover.
    Nov 2015
    Spanaway, Washington
    1
    First year closing this late due to purchasing a new heater. I took yesterday and today to winterize the pool. Everything removed, covered and stored.
    Now I'm thinking about the solar cover. I left it in the pool. We do get some freezing here and was wondering how this may effect the solar cover.
    Would hate to have to remove the winter cover because it's tied down pretty good all the way around.
    Index 26' round, 18,000gal, above ground, Intex Krystal Clear 2100GPH Sand Filter Pump, Hayward HP50TA 50000 Titanium Pool Heater, Aquabot Mamba pool vacuum(on separate pump), Clear solar cover, solar cover reel.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,541
    Re: Pool closed for winter. Forgot to remove solar cover.
    How much does it cost? If it is cheap enough you might want to take a chance and just leave it there instead of redoing all of that work.
    I am not sure anything will happen to it. It is really just like a liner so..........it should be fine until the Spring..............no telling for sure.
    Kim
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    I do not believe your solar cover would be damaged. The only thing I can think of is that water may fill and expand only in the area that the cover was cut. You have a round pool and this is assuming you cut the solar cover to fit the pool snugly. If it lays on the water and is lifted up and over the pool, there should be absolutely no issues.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Larryh86GT's Avatar
    Jan 2015
    Western New York
    93
    Solar covers are not cheap. I would do the work and remove it.
    Coleman 16' x 48" power steel pool.
